My new instal K3LA.........
First wanted to thank everyone on the forum for suggestions!!!
Finished my install yesterday K3LA 8.5 gallon tank 2 used 480c’s
Off the forums and Grahm white valve also horn blasters pressure switch!I used loctite 545 on all the connections expensive as he’ll but worth it not one leak!For the wiring I used 4 gauge from the battery with a inline 60 amp fuse too a monster power Y block then I added to each compressor a 40 amp fuse works awesome.When I mounted the horns I used security bolts or tamper proof bolts on the base and too mount the bells to the manifold.
I would post pics but don’t know how with a smart phone.
It was my choice to run the 8.5 gallon tank I’m not a physco blaster I know bigger is better no debate needed!
That’s awesome. The tank should be great with your K3.
I hope you can get those pictures figured out.
People ask how to wire the dual relay all the time and IMO you did i right.
you can do a picture text to your email address and It will show up in your mailbox… Thats what I do with my phone-non smart phone haha. but yes, you sound correct
