Here is an older video I shot and recently uploaded onto YouTube
Check it out
http://www.youtube.com/user/Chad123golf?feature=mhum#p/a/u/0/IR-Gvt3MPPA
Check it out
Thanks for the video.
His sounds a little higher pitched. I wonder if he’s moving towards you fast enough to make a difference. Did he continue honking after he passed you & was the pitch lower than yours?
That’s awesome that he played back! Sounds like the train had more air behind it. Do you remember what psi you were running?
He was going pretty slow due to the intersection. His horns are mounted on top and mine are under where the spare tire was. I was using my cell phone to record this video. Yes, he continued to honk a few times after he had passed. I did the same in return.
I was and still am running a 20 gallon tank at 150 psi. Like I said above, I was using my cell phone. Some of the people I work with have heard me at this intersection which is just a block from where I work and told me that mine is louder than the actual train in previous blows.
