Need help Installing a horn
My friend gave me one horn from the XL kit. I have only the horn and one 90 degree fitting.
As i understand i need a valve, air line, button and some fittings. Can you tell which thread is on the horn ?
Is it possible to install reducer (1/8) to make the horn not so loud ?
I am planning to buy 3/8in Shocker Electric Valve and install reducer right before the horn. If the horn will not work with the reducer i will remove it.
Welcome.
I would use a pressure regulator or an inline ball valve to choke it down. At least you could adjust it.
Haha you don’y hear that every day - someone trying to quiet down their horn…
Just use a manual valve, or make one easy enough (I use a 15mm plumbing gate valve) My Horns are as loud as I open the valve.:smiley:
Welcome to the forum. I agree with using a valve in case you really need it loud for some idiot on the road.
WOW! Thank you for the answers. This is really nice idea to install adjustable valve.
My schematic will be Electric valve and after it something like this one http://www.ebay.com/itm/1-2-NPT-Air-Compressor-Pressure-Relief-Regulating-Regulator-w-Gauge-Bracket-/300892955206?pt=Pneumatic_Hydraulic_Valves_Parts&hash=item460e9e2246
Please tell me which thread size is on the horn http://img526.imageshack.us/img526/606/hornz.png ?
Thank you for answers. Now i have all necessary info for the build.
I am going to post the photos when it will be done.
