im getting ready to install my setup and was wondering which air setup to go with. viar 480 duals or air zenith ob2 duals?
The air zeniths fill a lot faster 7 cfm
The Viaair fills 3.53 cfm
I say go with the air zeniths if you have the money since they fill a lot faster.
If you got the money go zenith. If your pinching pennies go viair. Bot great compressors. Just one faster than the other.
Also consider longevity. To produce more CFM, the AZ’s either have a larger displacement or higher RPM. If it’s from a higher RPM then its longevity is questionable due to the technology envolved.
