I’m looking for a lanyard-controlled SPST momentary contact normally-off switch to use to control my train air horn system. I already have a fully functioning air horn system on my Jeep that runs off a belt driven York F210 compressor that doubles at providing air for air tools on offroad trails as well as airing up my tires after I’m done offroading.
The only problem is that I have to push an overhead button located on a mount welded to my rollcage to blast the air horn and it’s not all that convenient. I’d like to mount an overhead lanyard pull momentary contact on-off switch but I can’t find one. Can anyone help?
Again, everything works fine. I already have a solenoid actuated air valve controlled by a momentary contact push-button switch. I just want to replace that push-button switch with an overhead lanyard switch much like the truckers use.
If you know where on eBay I can find exactly what I described above, you’re a better man than I am. Remember, I am only looking for the lanyard operated electrical on-off switch itself, not an air valve or solenoid actuated air valve etc. Chain actuated air valves I can find, a lanyard actuated electrical switch to control my solenoid air valve I can’t.
So if you can find it where I have failed over the past couple months of on and off-again searching, a link to the lanyard operated electrical on-off switch you say is available on eBay, that would be much appreciated.
Finally… after many months of not seeing the switch I remembered seeing on ebay, it’s just now back again. From its photo it looks used and maybe homemade but it’ll work. Mission accomplished.
Radio Shack has all kinds of switches but I don’t know about lanyard controlled ones. You might be able to rig up something where the lanyard activates a standard SPST momentary switch.
they are basically a push/pull momentary on/off switch attached to a piece of sheet metal and about 16 inches of small chain. its designed so that you dont have to run air lines up in your vehicle…
COLE HERSEE 9109
12 volt normally open pull to close momentary switch… meaning normally off, pull on, release and it returns to off. It has a stud with a 3/32" hole that you can spin one of those ringy things for keys in and attach a cable to.
Got mine for 15 bucks shipped to my door from a site called IPS depot.
I was looking for the same thing for about 4 years now, I never thought to look but when I was doing some work on our fire truck i noticed it had the switch, not a valve and googled the part number right after i changed my drawers and took a xanax to calm myself down.
