Need some help guys... new to the train horn stuff
so i just installed the shocker kit. sounds awesome… but i want to do a few more things…
like… how do i make it dump the air out and go psssssh so i can scare people that way as well like people do with bagged cars…?
and can i install a p/a system to this easy now?
http://www.hornblasters.com/products/details.php?i=hornblasters-30w-public-address
is that kit good to buy?
thanks everyone for the help… ill post videos asap… going to do some videos tomorrow i think… if i can get a buddy to help video
instead of having a drain cock at the bottom of the tank, i think some people run airline out of their car and have a solenoid there. that way they can flip a switch. it opeans and dumps out the air/water mixture
and details on how to do that? what i need to buy… etc… thanks:D
whatever size fitting goes into your tank for your drain cock. then airline that fits that fitting. It doesn’t have to be huge, like 1/4th or 5/16ths would work, then a fitting to go from the airline into the solenoid. the solenoid itself, then a fitting from the solenoid to some more airline. probably a couple zip ties, and wire to ground the solenoid, as well as to run it up to the drivers side, just have it on a toggle switch and run that wire to the battery or 12 volt source. I dont think it would be that hard. and the most expensive thing would be the solenoid and fittings.
Hope that makes sense
I have this on mine when i redid my setup…
The port on bottom just run a line from it down so any moisture will find its way in line, then just run that straight to a solenoid… I had mine set up like that for a couple months.
Couple weeks ago, i thought why cant i add a horn to that solenoid instead of having just air come… So i bought a set of psycho blasters and they are working great! Its not too much moisture, but i went with them cause there cheap in case it does mess up the diaphragms…
Pressure Release Valve:
All you need are two air line fittings, some line, and an electric valve. We can provide everything you need if you want. Just give us a call (1-877-209-8179) and we’d more than happy to help!
Public Address System:
It’s completely independent of your horn system and very easy to install. That ones pretty fun. It comes with yelp/wail sirens and an air horn sound on top of the PA. I would, however, recommend waiting a month. We’re releasing a new PA in late August that will blow that one out of the water.
