So I’m ready to go with a bigger tank. Also a whole new setup. I plan on running a tank similar to the 5gal. 8 port H.B. sells. The 4 ports across the front will be for the horns. 4 ports, 4 horns, 4 air valves. Is their any way to run a bigger air line to each horn? My setup would call for like 6-8in total in air line from the valve(mounted on the tank) to the horn, for each horn. For now I will keep the compressor, and just have it take forever to fill, unless I come across a cheap one and run 2. Thanks in advance!
this is my current setup. In my 91’ VW Cabriolet.
