mmm… but why don’t you want a presure switch?? all the hornblaster kits come with a presure switch like the one you post or like this one http://www.hornblasters.com/products/details.php?i=viair-110-145-pressure-switch … but if you don’t want one you will have to get a gauge to know when the tank reach the presure you want and then turn the compressor OFF and ON you know… a compressor without a presure switch won’t know when to stop or when to star…
The pressure switch tells the compressor when yo turn on and most important when to turn off…
So if your pressure switch is set at turning on at 110 psi, and off at 150 psi, the compressor will do just that…
The relay is a fuse basically… It mainly allows the compressor to turn on when the ignition is on… otherwise if you have a leak when you are not in the vehicle , and the pressure drops below your pressure switch setting, the compressor could click on and drain the battery and possible risk damaging the compressor!
That grey box type is the best one to get , it is fairly waterproof, has all marked leads too which is easy for hookup… good luck, any more questions feel free to ask
