New from Texas
Hello everyone, getting ready to install a Hornblasters train horn on my new Ford F250 pickup. I’m sure I will have questions about the install.
Welcome to the forums!
Welcome to the forums its a pretty easy install…
It’s not bad, I just finished installing them on my 02 f250. I bolted my horns to a piece of sheet metal and attached that to 2 of the support ribs on the bottom of the bed, just ahead of the spare and just above the 3rd member. I mounted the valve on the crossmember that holds the spare. I mounted the tank on the outside of the frame just about even with the transfer case. I mounted the compressor on the inside of the frame, to a piece of 1/4 inch plate so the compressor would sit upright. Compressor intake is inside the cab behind the rear seat. I love it.
Welcome & good luck with your install.
Welcome. Pics are appreciated if you can post them.
Thanks for the welcomes. Look forward to getting my horn installed and being a member of this forum.
Welcome from the UK - good luck with the install - dead easy to fit!
