I made the mistake of getting a Maximus level 4 kit before I found this forum. It was decent at best but now my compressor will not run. What can I do to fix this? My switches get power and my solenoid clicks but not air. I also looking for a new set but checking the selling forum. Thanks
Check the fuse. Make sure your grounds are good.
All that seems to be ok because it all runs to the same relay. The compressor is the only thing not getting power
Welcome to the forum.
I had the maximus kits and had to change the compressor that came with there kit in about 2months with same problem you are having now.
Checked all grounds and power wires, relays, and switches. Was a dead compressor.
Sorry you just found the forum. If any help is needed feel free to ask. You came to the right place.
softballer - sounds like you’re not the only one with quality issues. Maybe the compressor is dead…
So the compressor is grounded to the same place as the relay? If not, make sure the actual compressor ground is good.
