so, a while back my compressor did not kick off with teh pressure switch as designed. so due to not having access to a garage and the cold weather i temp. wired it up on a toggle switch for manual control, because replacing the pressure switch required me to pull the tank due to its location.
so, this weekend we had nice weather, so i pulled the tank and replaced the switch. now i have a significant air leak around the switch, it still will not kick off at 200 PSI. it is a sealed switch ibought from hornblasters.
gonna try and fix the air leak this weekend, did i just get a bad switch or could i have relay issues?
and i took my toggle switch and wired it as it was originally wired.
