Based on a 400C Dual Pack - filling 35-inch tires from 15-35 PSI.
Lance, check you out, cool vid. I’m having a tyre airline facillity on my install, how long to do 0 - 30psi?
Subscribed.
Thanks man!
To answer your question:
What size tires?
What size tank?
-If you have low profile tires, they don’t require much volume at all - so you can likely fill the tires as fast as the inflation gun you’re using will put air through the valve stem.
