Newbie at horns need help with kit.
Hello all i have an F-350 long bed none dually and i want to put together a nice kit with loud horns. i want to do a Nathans air chime set for the horns and two 5 gallon tanks but other then that i have no idea what i need. what valve, lines etc would i need for this kit? Im good mechanical wise for the install but no idea what i need for the kit. Please help and thank you all.:slight_smile:
If you call hornblasters they will tell you everything you need.
But basically you are going to need:
horn
compressors
valve
air line
Pressure switch
toggle switches
etc, probably more ear2ear will add haha
Nah, you covered the major parts.
Welcome to the forum studded. You’ll have to decide what pressure you want your tank and horns. That will dictate compressor options, pressure switch, and if you need a regulator (not a necessity). Also if you want an electric valve or manual valve which is more authentic sounding.
1/2"DOT tubing is pretty standard, but you can step up to 5/8"DOT or 1/2" ID hose. It makes a difference.
Are you thinking K3 or K5 and where would you mount everything?
Most importantly!!! A Pressure release valve & draincock as well.
Give Hornblasters a shout and they will most defo hook you up.:smiley:
Welcome to the forum. These guys have already covered the basics.
