no air to tank
so i have everything running perfectly, but the only problem is it is not pumping air into the tank. i can feel air coming out the inlet port, but not the leader hose to the tank. any suggestions? where did i go wrong?
thanks in advance guys ’
btw i have the shocker 240 kit
Make sure your check valve is facing the correct direction on the leader hose.
