Hey everyone, im new to the forum but been lurking since the first day this forum started. I have a 400c viair, 3 gallon tank, 2 sets of the conductor (8 horns) not sure what size air lines (stock ones) looking to upgrade:)
welcome to the forum!
WELCOME! nice FJs
thanks guys
Welcome! upgrade to 1/2 air line and valve here:
http://www.hornblasters.com/products/details.php?i=shocker-4-1-2-in-valve-upgrade-kit
and try to get a 5 gallon air tank and a 480c viair compressors or a 380c and run the 8 horns at 200 psi.
That was how i was running mine, i had 8 of them to at 200 psi and 1/2 air line and valve with a 5 gallon air tank and a 480c compressor.
you think it’ll be ok if I run 1/2 line 480c viair and keep my 3gallon tank? I have nowhere to put a bigger tank
the 3 gallon you have is rated 150 psi max but you can put 200 with no problem at all… and the 480c will do fine!
YA definitly… 3 gallon and a 480c are good. but ull be hearing the compressor alot more cuz thats more air going out at once
thats right
nice fj mike i have one but it is a 1980 model its an fj40
