one bell from nathan
I was just wondering if one bell from a nathan airchime, will work with a 2 gallon tank @ 150psi
i heard a K3 / P3 won’t work as good with a 2 gallon tank due to the cfm.
if it would work , which airchime bell has the best sound, when used seperate? anyone knows ? :slight_smile:
Or could someone have a listen :slight_smile: i’m interested in a nathan airchime
The longer the bell the deeper the note. The shorter the bell the more High Pitched so Keep this in mind as you search for you K bell. Also not you will need a sort of custom mount to be able to blast the horn due to the way that the horns are designed.
i thikn ive seen these single mounts that airchime makes, where if u just wanna have one bell you can… im not sure how to find it tho
why don’t you sell your kit and save for some k3 and a 5 gallon air tank?
P-3 use less air also it would work on small tank :slight_smile:
i can’t fit a bigger air tank in my car… no where… neither can i fit such a huge horn on my car
im looking for the bell that has the most authentic train horn sound i guess…
triubb let me hear your #4 bell and i might buy it
4 is going to be way to high pitched… u should llook for a #1
see this pic…it has the single manifold
Could you just use a smaller tank. and link the 2 tanks together?
i’ll probably be buying a K3LA soon… after i link another 2 gallon tank to my system, just have to find a seller of those in the Netherlands
I can get one for 450 USD , along with these custom mounts so i can mount them seperate
yep thats how i have my setup and i love it :slight_smile:
