so i have some holes in my frame on each side where my spare tire used to be, i just wanted to ask what everyone thought of using toggle bolts to hold my steel up to which the horns mount. imo i think it should hold well but looking for opinions thanks everyone.
What kind of Horns are you running?
k3la
I would not chance it. I drilled holes in the frame and built a whole bracket to hold my tank and horns with 3/8" bolts with lock nuts. Its your investment do as you please…
I personally would not do it.
The ones I just looked up said you need a 5/8" hole and then the threads are still only 1/4-20. So you’ll most likely have the drill out anyway.
I agree with slippery750… 4 - 3/8" bolts with nylocs or something similar.
