Does anyone have measurements of P3 bells? Length and diameters.
I want to replace my shockers with a P3 (with individual mounting brackets) but the shockers were a tight fit.
Thanks!
You can find dimensions for each of the individual P3 bells on the Microprecision website:
http://www.microprecisiongroup.com/nathan-airchime/technical-info
Thanks, unfortunately I have to enter a name and password to download the spec sheets
But the basic dimensions will do I think
If you click on the menu on the left, you can navigate down to the individual horns - e.g. :
http://microprecisiongroup.com/docs/images/MODEL-P1A-SINGLE-TONE-277Hz-LOCOMOTIVE-AIR-HORN-page1.jpg
Looks like there is minimal difference in diameter
The P3s are a lot bigger than the shockers, at least in diameter. I was not able to make them work on my car, whereas the shockers fit into the space between my radiator and crash bar.
Ok, guess I will have to stick to the shockers. I have them in the same spot as you, and there is no extra space. Getting a P3 shipped to NL is an expensive gamble ![]()
