My hornHi.
Sorry question. What pressure should be for 1 single bell P3?
I applied pressure of 135psi, but the sound is very high (as a whistle) and quiet.There can be a low temperature.
75psi OK sound! Why?
Thank you for the full answer.
is this the longest bell? on the p3? if it is it should have a deep tone to it, you may want to open the back cap and inspect it, make sure its nice and clean, the diagfram could have a rip in it or bent from wear?? you can reform a diagfram from thin sheet steel , or find a restoration kit for it. (best) 100 psi should be good nothing over 150. the more psi the hier the pith but should also have a good loud sound to it. best bet is to open the back and overhoul it with a new kit. or change out the sheet steel diagfram.
I have understood thanks.Inside it is fine. It is necessary to try diagfram.What thickness diagfram. Sorry my language.
с прибытием на сайт:d
И тебя тоже. Блин пробовал дудку через кислородный шланг не звучит.
Понял одно-от клапана должна идти твердая магистраль (без расширений), а через мягкую ни как (по ихнему переводу не взрывается).
так поставь трубку пвх
[quote = слава4х4; 38759] так поставь трубку пвх [/ quote]
Пока пробовал из того что по рукой, сделаю
i would say same thickness . if you could get a micrometer?
Ок i try
is it bent or has hard marks from use? check ebay i have seen rebuilt kits for train horns? if you find a seller you can ask a question, ask if he can sell you only that certain one?![]()
