Does anyone have any gaskets for a p3 they want to sell. Or is it ok for me to just buy some cork and make my own and is there a specific size for the hole that i need to make the gasket.
Thank you Justin
Thank you Justin
You can make your own. Just be sure they make a good seal when you’re done. I made some once that leaked and ended up using a roll of that black gasket material from the local parts store. Also, you can use the manifold as a template for the size of the hole. The factory gaskets holes are the same size as the holes in the manifold.
thanks Honda guy. yea cork was on it and i was thinking maybe i should put that back on but i know there is def some better gasket material out there so im thinking ill just making some myself.
