Panic alarm train horn? 02 explorer
Hey I was Just wondering if any one can help me find out where the panic alarm wore would be so I can set it up so when the panic alarm goes on the train horn does also. I would love to go ontop of a roof and park my car and let the panic go on as people are going by help please,
Kody
Also I have seen this In a YouTube video so I know it’s posible…
Follow the wire to your stock horn.
That is the wire that gets juice whether it’s panic or the button on the steering wheel.
Well I found my regular horn but I can’t get to it I just need a wire that I can plug the horn wire into and have a wire coming from that connection to my button so I can have the button and panic alarm work also anyone know where I can locate this wire because I can’t get to the horn
Can you see the wire to the horn?
Follow it up and find a clear spot to cut it and insert your own “Y” style connector. One part of the “Y” will go back to the horn, the other inside the cab of the truck to a switch to turn them off or on. On would make the panic horn/regular horn work, and off would be just the regular horn.
Ok two things can I set it up so there is two “y” connectors and have one go to how I have it set up now if you have an email I can send you a picture of it also I can’t find a clear clear opening I can only get about two centimeters of it out and to work with. Has anyone accually done this before on an explorer or know where I can find a big enough opening to work with I can’t take apart the wheel covers because of my plastic trim the same power wires go to my lights (parking, fog) I can get the wires out enough to find the color of the horn wires which I have not done yet I will when I get home so if someone can tell me a bigger opening where these 4 connect I can cut into it and tell what one is the horn wire
what I want to beable to do is have so when the switch is off I can use my button that I have set up now and when it’s on it will go off to the panic alarm locking alarm and regular horn I’ll try toupload a picture but I have it on my phone but I can email it
Bump
I found out what color wire it is it’s a dark blue and it goes to the inside fuse box does anyone know how to access those wires
well seeing as you havent even said what kind of Vehicle it is … no we dont know how to access those wires
Yes I did list it in one I my post but it’s ok now I found it.
I have my train set up to the regular horn so when I press on the wheel it goes off and when I double click lock it goes off for a quick beep and my panic alarm works also which was the main point in me doing this lol I have a clamp on my positive horn wire with a power wire going from there to my horn and I still have my compressor set up to the fuse box with a switch 3m double side taped to my center coloum I’ll try to get some picture and videos up
Glad you found it. Yeah a video would be nice. I’m having a hard time figuring out what you’re doing.
