i have the shockers xl wit a 2 gallon tank i just ran them to 200 psi but now they are high pitched as h*ll could it be cause the 1/2 hose is going to a 3/8 port? or do all shockers have this problem at 200 psi. ive checked the hose for kinks and everything and cant figure it out!!!
My friend’s did the same thing at 200 PSI. They’re so-called “rated” at 200 PSI but I don’t buy it. I’ve only heard 2 sets at 200 psi and they both screwed up rather quickly. Once dropped down to around 140-160, no problems.
i just upgraded to 1/2in everything also, and now my horns squeal. they sound just fine around 150 though, im thinking of just getting a 150 pressure switch, as i need 110 max for my air suspension soon
Hmmm… This is weird… If u guys are having this continuous problem please let us know so that we can see if we can resolve this for you… Sorry for any inconvenience that this may have caused…
its more like a screech. not a squeel haha. I just have 1 horn doing it. Trying to figure out how to fix it. Rigo said air tool oil. just a couple drops after the solenoid. Im going to try that, if not someone said tightening the bolts on the back caps? idk lol I will get it fixed. Its pissing me off haha.
I’ve never seen a “tunable” shocker horn… The screws just hold the cap on as far as I know… plus they’re glued on, I wouldn’t recommend messing with that.
It won’t help anyways… As Curtis said, the pressure has nothing to do with tuning.
Ive had mine honk at 200, and it is loud as fuk. its amazing, and has great tone. that happens when its wet outside lol idk. but others all three sound great but 1 horn sounds like shit and ruins everything.
