I’ve experimented with a temporarily installed mini-regulator and found that I’m liking 100psi for my Shocker XL’s However, with the following aftermarket things already under my hood and behind the nose/bumper of my truck, I’m super low on space:
[ul]
[li]240 AMP (nominal) HO alternator[/li][li]Mosfet-based dual rectifier (for bidirectional battery isolation)[/li][li]Twin Diehard Platinum (rebranded Odyssey) AGM batteries[/li][li]0AWG alternator, ground, and battery cabling w/ 1 pair 300AMP rated ANL fuse terminals and fuses (1ea per battery line from dual rectifier)[/li][li]WARN hidden winch carrier[/li][li]WARN winch[/li][li]1 pair of Rigid SR-series 10" driving (LED) lights custom mounted in stock bumper slits/openings[/li][li]Custom-built environmentally-sealed relay/fuse box (for add-on wiring and relays) on custom-fabricated mount[/li][li]Aftermarket 10,000 CFM e-fans[/li][li]Aftermarket upsized radiator[/li][li]Aftermarket upsized transmission cooler[/li][li]York 210L engine driven compressor on custom-fabricated aluminum mount[/li][li]Load genie check-valve/unloader[/li][li]Coilhose Pneumatics 1-816-8924M coalescing filter (w/ metal bowl) on custom-fabricated mount[/li][li]Pneumadyne M30-250-3-90W air manifold with:[/li][LIST]
[li]Pressure switch (160 on / 200 off)[/li][li]250PSI liquid filled gauge[/li][li]Dakota digital 0-400PSI electronic (gauge) sending unit[/li][li]235 PSI relief valve[/li][li]Plumbing to vehicle’s rear air manifold (twin 2.5gal tanks and rear quick disconnect tied in from it)[/li][li]Plumbing to vehicle’s front quick disconnect[/li][li]Plumbing to HB solenoid for Shocker XL’s[/li][/ul]
[/LIST]
My air system is engineered as a 200PSI system – with all components having a nominal (not burst) pressure rating of 200PSI or better. She usually hovers in the 188/194PSI range when the tanks are full and the compressed air has been permitted to cool.
Notice no permanently installed regulator. That’s because when I run air tools off this system I connect a regulator to one of the vehicle’s QD ports via a 3’ whip – and then use a Flexeel hose to connect the tool to the whipped regulator. This was by design as I didn’t want a fixed/pre-set regulator at the vehicle’s QD ports since I often need to dial pressures up or down as much as 20PSI based on the tool I’m using – and I had deep concerns about a regulator withstanding the elements for any length of time.
With no permanent regulator in this setup … and all that stuff crammed under the hood and behind the bumper/nose, already, I can’t find the space necessary to mount a Norgren or some similarly-bulletproof regulator that can handle both the heat and the volume needs I have. However, I think I’ve got just enough behind-the-bumper space left right near the HB solenoid to mount a fixed/pre-set regulator like this one:
http://www.protect-air.us/save-air/protect-air-inline-pre-set-reg.saveair1-4npt-7bar-100psi.html
The SaveAir pre-set regulator appears to be able to handle my inlet pressue, and while the thermal rating is lower than I’d like, the behind the bumper location should present no thermal problem. My one concern is air volume, but I think this can handle the necessary CFM, too?
I’d like opinions, please … because I’m about out of options for a permanently-installed regulator … and my temp-installed regulator just isn’t suitable for permanent placement under the hood (it’s a micro unit, mostly plastic, and won’t survive) – and won’t fit in the remaining space behind the bumper (and still be adjustable).
