Pressure Gauge problem....
I just got my HornBlasters pressure gauge in and went to go put it on my tank and my toolbox wont close. The only visible place for it is on top of the tank and my lid hits it. See I have to have a adapter for that can screw into the tank and then I screw the gauge on it…is there a way to just mount it in my cab or would it just be smart to go buy the kit hornblasters have…i don’t really want to though…
What did you get the digital gauge? If so you can Tee it anywhere on the tank or get a pipe nipple and Tee and put your leader hose on one end, then have sensor for sensor on top of tee then right into the tank. run your two wires back to guage in cab.
No I got this
http://www.hornblasters.com/products/details.php?i=hornblasters-200-psi-2in-gauge
Well you could do the same thing as i stated just put on top of tee where I suggested sensor to be.
Get some 1/8" airline that is meant for gauges, pick up appropriate fittings to reduce / adapt , and put in cab… Thats what i did.
