Properly ground in in truck bed?
OK so I’m 90% done with my horn re-installation but I am having a complete brain fart.
Don’t know where or how to run the grounds from the pressure switch and the compressor.
A- Should I get a thick gauge wire to run the ground properly?
B- where in the truck bed can I ground, if at all? If not, I got to run wires out to the frame?
I haven’t had time to ask Dad, the electrical engineer…
Compressor grounds to the frame, and use 2 gauge or bigger.
Pressure switch can ground off the compressor.
Thank you my friend. Hoping to grab at Home Dopey (Home Depot) on the way home tomorrow.
im 90% done. Been looking at the pics of installs on other Dodges. one other new question…I see that HB recommends the compressor be higher than the air tank but I see examples where its not. Further, I dont see how folks are installing their compressors underneath the trucks and not getting wet if in snow and puddles. What gives?
I tend to get wrapped up in “get’erdone”-itis and dont want to rush this job. Want to do it right
Success… now just have to mount the manual valve
