Running an 8.5 gallon tank at 175psi with a manual valve, but I have almost 8 feet of line between the tank, valve, and horns. I lose quite a bit of pressure running from the tank in the bed, to the valve in the cab, then back out to the frame rail where the manifold is mounted. I also don’t hit the horns with a full on blast unless someone needs it.
