Heres my other truck, its a 2000 1500 that came with a 4.8 nv3500 5 speed 4x4. Im in the process of installing a 5.3, M12 T56 out of an 04 GTO along with a front mount turbo kit. Heres the thread I started on another site
Heres the truck on the lift at my buddies shop…
We wanted to get the truck moved this weekend, and also get it ready to drop the motor in. While the motor was out, this would be the time to put in the new injector harness’s for the new 60# injectors.
Heres the stock injector and clip, vs the new clip and injector…
While my buddy worked on that, I wanted to get the trans cross member finished up so that would be ready to go. This is what we started with. I cut some steel to make a couple of gussets and then burned em in.
We finished up with the truck and went back to my buddies house to work on the 5.3. I got it out of an 02 Avalanche and it had 77k on it for $350 bucks.
Pulled the valve covers and was pretty surprised at how clean it was. The intake ports had a lot of carbon but other than that, so far it looks pretty good. The guy I bought it from said he ran Royal Purple from day one. I had bought a cam package for a friend but they had backed out so I had a 216/220 114lsa cam, LS6 springs and 7.4" hardened push rods so that what we put in the 5.3. Here’s us swapping out the LS6 springs.
Springs all installed and cleaned the motor a little.
Decided to throw on the log and turbo to see what she’d look like and for a little motivation. Its a KBRacing turbo kit and I had purchased a used Garrett GT4202r 74mm compressor wheel 1.15 A/R exhaust housing. The exhaust housing is a little big for my application currently, but I bought it to be used on my 6.0 when its done. I wont be using these valve covers just yet.
We also got the carrier bearing cross member welded in the truck as well and started on the fuel pump install. We have lots to do but hopefully next weekend we can get the motor and trans in the truck, and start to assembly the turbo kit.
Im really excited about working on the truck again and cant wait to get her done and take her for a ride!
Ill keep everyone up to date as much as possible while working on the truck.
Let me know what you guys think and if you got any questions…
