ok as stated in my introduction thread, i bought a K5LLA horn off a member on ebay… so what i was wondering was will HB’s 540 onboard system include EVERYTHIGN i will need to get the horn doing it’s thing? Just to be clear i’ll post a link on here to what i’m talking about… Will this kit come with all the air line, fittings and solenoid valve etc… that i will need to get this baby honking? i tried to contact them for 2 days but no luck!! anyways here’s the link… All your help will be greatly appreciated!
It does not include the airline or valve. I think it has 1 PTC fitting for the line out.
Take note that kit has a 5 gallon tank. Most people including myself would recommend the 8.5 gallon for a K5. It kind of snowballs though because then you’re technically past the warranty of a single compressor.
If you can get a hold of somebody @ HB on Monday, they can piece together whatever you need.
ok thanks man just saw where this was approved… i dont see need for the 8.5 gal tank… i wont be blowing it for extended periods of time… probably a short burst or no more than 3-5 seconds… if the 5 gal can handle that then it will do fine for me… I’ve tried several times to contact HB via phone and nothing back… i would peice my own kit together but i dont wanna spend my day off going all over for fittings etc…
ok thanks thats really what i needed to know… so if i buy 1/2’ hose and 1/2’ solenoid valve i should have everything i need to honk with the 540… correct?
