So i have been thinking about painting my k5 but i couldnt decide upon a color. I didnt want anything in your face, but something more along the line of a gunmetal color. I did find this cool black metallic color that can come off as different shades when in the right light.
If you were going for gun metal look then I’d say Mission Accomplished. Should match the truck very nicely.
So are you going to mount those babies permanently now that you’ve got more air than Michael Jordan, or are you just throw them onto the roof for special occasions?
Hahaha i happen to stumble across this again and didnt see this question. More air than michael jordan LOL
Well i dont need to mount them permanently cause i have a k3 behind the front bumper which is permanent.
So yah its for special occasions… like car shows, new years, independence day and so on.
Only problem is i dont have a pump big enough to fill that 60 gallon. I dont think my york is worthy enough. So im planning on building a portable compressor with no tank. So like just a gas engine and a pump.
well technically it would be 70 gallons cause ill rig the 60gal to my OBA
ok so I did the math and I believe I will have to rev my engine 1000rpm which means my york will be at 1653rpm
in case anyone wants to check my math:
Harmonic balancer is 7.72"
Alternator pulley is 2.14" Serpentine diameter and 2.75" V-groove diameter
York pulley is 6"
6000 RPM must be an air conditioning application because in an air compressor application the crankshaft is spinning so fast it splashes the oil away from bearings which will seize it in about 2 minutes.
Its maximum continuous RPM is around 1800 to 2000.
