im going to be using the square D brand pressure switch for my setup. i went to the electrical wholesaler, Eecol, and they need to know quite a bit of sub-numbers. which ones do i want? i think i need the one that has a 40 psi diff. adjustable from 100-200, 150 psi shutoff, and 1/4" npt external connections. is this correct? i also could not find the option for an unloader valve. does that just come standard?
HB includes a leader hose and check / unloader valve with the XD3000 and the square D pressure switch will work fine with it because it already has a built in solenoid.
who said i was using the XD3000? youd never catch me wasting that much money on a 12v pump! EDC all the way dude. but i guess IF for some strange reason you couldnt fit an EDC under your hood you could run an electric pump.
too bad though, because if you dont have room under your hood for an engine driven pump, chances are you have a tiny alternator that wouldnt be able to handle the current draw of the XD3000
Excuse me, wasting money? There are plenty of reasons for spending that kind of money on an XD3000 and I’ve presented them in this forum many times. You have the right to use and say whatever you like but please think about how you present it.
Besides, I was referring to our compressor already having a solenoid and that a Square D pressure switch works very well. Also that HB includes a check / unloader valve with it.
You asked and I answered. It’s also my job to promote our product.
