My one set of horns the solenoid is sticking a bit since it’s cold out, (12 degrees)
Can I run a small amount of rubbing alcohol or antifreeze through the airline to free it up? Any pro’s/con’s using either in my airline when it’s cold as a well diggers a** outside?
If it operates at all, add about a small amount of antifreeze to your tank and that should keep them operational.
Move South hahaha
Dixie, you’re so funny…
A job that pays about 70K a year doesn’t warrant moving south for same job that pays 18K a year!!!
Air Brake Antifreeze
