Never seen this before…1000psi!!! wtf is this???
Sad, someone will be mislead by this - and may destroy a perfectly good horn.
Hell yeah loudest train horn ever…ONCE! ha ha
Buyers might as well plan on buying new guts for their horns with every tank fill…lol
I understand the idea… The bottle will hold 1000psi like an oxygen bottle will. With a regulator this might actually work, but that is not how it is advertised. I sent him an email through ebay and explained this to him.
he emailed back and said that his solenoid valve has a .156 orifice. This is a joke. That might work with high psi, but the volume of air is not worth a darn at lower psi…
I wouldn’t want to spend that kind of cash and not even get a compressor… or more than “one” honk.
However, to get the pressure over 200psi you need to fill it with compressed gas!
A good friend of mine has a compressor that will fill over 2000 PSI. This guy is a jacka:eek::eek:
^ agreed. What does he want you to do. When it runs out, go fill it with helium?
update Apparently Maximus is making these. From www.maximushornsystems.com
http://www.maximushornsystems.com/trainhornkits.aspx?CategoryID=62
Only thing worth anything is the sandcast bells style k3 manifold.
^ you can tell them are sand cast?
Actually the bells are newer 1995 to present day raised letter bells, and thats an old 1978 or earlier sandcast k3 manifold.
I know alot about K horns. But not everything yet.
Random knowledge. From 1978 to 1995 there are 7 different configurations/styles of the 4 bell. 1995 to present day there are 3 different 4 bells that I know of.
I know my bells are die cast and numbers 1,2, and 4a mounted on a low manifold. Which makes a K3LA. That is about all I know… lol
A pretty easy way to tell the difference in the manifolds is the diecast manifold is alot smaller and skinnier. The sandcast is taller and thicker. I’ll post a comparison photo when i get home from work.
someone should email that guy selling the scam set a link to this thread hahaha
As promised, here’s a sandcast manifold:
And here’s a diecast:
^ I guess mine is a diecast manifold too then…
Looked at the kit…no regulator. Just a pressure gauge mounted to the tank neck. I call the BS card on this one too. A lot of money for a 1x blast.
1000psi. I wonder how loud it would be? If it even made noise. Someone try it, and get a video… Ill be watching
lol
