Ok, so I take my Conductors Set out this afternoon for Bixby1980 (he has not paid me yet , SierraK5) and we tipped the tank over after pulling one of the fittings and rusty water came pouring out. Should we add something to the tank or clean it out periodically?
I am getting a 20 gallon tank and it has a water drain valve on the bottom, how often should they be drained?
My suggestion is to add a valve to your system that will drain the tank with a small switch in your cab. It also allows you to “scare” someone on a much smaller scale bcuz it’s still loud when you’re near it, just air escaping. (something safe enough to use on …well…your mom or so )
Also this way, you find yourself hitting that switch daily as well, keeping your tanks as dry as possible.
I have the wing-nut looking valve on the bottom of my tank, should I drain the pressure before I blow out the condensation, or leave it at 200 and slowly twist the valve? How long should I drain the tank once the air is expelling? Do I let it blow out the bottom until all the air is expelled from the tank?
its called a drain cock but anyway…the best and easy way is to hook up a sel. valve… and put a butto on your dash to drain it like i do… plus u can scae ppl with that…haha
http://www.hornblasters.com/products/category.php?class=6
Pick a valve, any valve… The SMC and the Airlift are very good. Any size will do, it really is a lot of fun to scare people with the valve sound. You’ll see, you’ll see… remember to use the coupon code Forums!
-Matt
or just call
1-877-209-8179
