Hey guys, I’m running a small 1 gallon tank with a pressure switch and the compressor main running to it, although i want to add another 1 gallon tank, now would it be do-able to run a line from my main tank, to another tank and still have everything be okay pressure-switch wise?
Ya u just hook one air line between the tanks to link them the air pressure will build up in both tanks at the same time just make sure if ur using big air tanks u have a compressor that has 100%duty cycle (which means it can run for long time with out hurting the compressor.) Ur only running to small tanks so u ll be ok with ur compressor setup.U only need one pressure switch like u have already. Make sure u check for any leaks and use Teflon tape on all ur air line fittings.
He just means like a kink(bend the blocks air flow) in the air line or anything inside the airline that could block it from flowing air from passing threw it
