Well guys I’m thinking about selling my K5HLA and dual OB2’s with two 5gal tanks. This setup has never been used since I purchased everything and the compressors are still brand new in box from Air Zenith. I’m wanting to put 250/200 injectors in my truck, and something needs to go.
How much for the K5s?
As of right now I’m not looking to part it out. And not sure on a price I got $2000 in this setup and the injectors I’m looking at are $1500.
Ah dang, well Im sure youll find someone. I want either some K5s or some Leslie’s for my rat rod truck Im building. I have air ride suspension so I wouldnt need the tank or compressors.
Also forgot to mention I have the 1L,1,2,3,4a bells together and even have the 5 bell to go with everything!!! Along with a new manual valve!
If you added the 5 bell wouldn’t that make it a K6?..lol
Yes but the 5 bell is in a box. I could fab up a K6 if someone is interested!!!
can you post some pics of the bells
Do u still want to sell horns I’m interested in just the horns
Did you sell your system? Would buy the whole set if price is right.
Thanks
Welcome to the forum “STxFarmer” & “clodfan101”
Is that an OEM air ride? How would you hook up the horns to the air ride compressor? Is that risky? I’m asking because my truck has a factory air ride and it would be cool if there were a safe way to hook up the horns to the existing compressor. Guess I would need a tank too. Don’t think the air ride has a tank, it just fills the bags directly.
Most aftermarket air ride kits will have a 5 gallon tank and compressors along with bags and hoses. So him saying he has air ride would imply he already has the tank and compressors so hooking it up would be as simple as adding a valve and horns to a port on the tank.
Very small compressor that is not designed to put out much volume or pressure. Very different system. Now if you have an aftermarket air ride like I do on my Chev 1 ton then that is different. I have no leaf springs but just bags, air compressor for it and storage tanks. Could run a horn system but not for long as the fill time would be long.
thanks for clearing this up guys. I had no idea aftermarket air ride kits came with the extra tank. Guess i’ll just leave my OEM suspension alone then
