In front? Would rather hide it a bit, like behind the grill, would it be possible? Also the compressor would be in the trunk, so i should find a way to pass the air cable somewhere.
Yeah, plenty of people have mounted them behind the grill and/or bumper of small cars. You just have to jump in and see where they’ll fit. You can place them any which way and they’ll still be loud. You can search the forum for other Corollas too.
I’m doing the same thing this summer with my K5. Just gotta tear the grill off and start holding the horns in there…
Ive heard that if i point the horn on the ground, they will be louder, is that true?
Anyway, ive looked in my trunk, there is a rubber cap under the emergency wheel, it lead right under the car, but there is no hole so i can screw the air tank in the trunk, will i be forced to make hole or there is another solution?
You’ll probably have to drill a few holes to get everything mounted.
So i received my package, i was thinking to connect my compressor that is in the trunk, at the main battery in the front, i have plenty of cable but i was wondering if that was fine.
I was wondering what was the switch that was in the package for, and how i could pass the wire from outside the car to inside my car to connect the switch.
And i got no idea how i can trigger the valve to honk the horn.
