what u guys think i got the shocker set up with 10 gallon tank 200 pressure sensor 1/2 parker hose on a 07 f-150 on 24’s in florida
my bad for what i say before lol…
3 hp, not 3 oasis compressors. I say go for it. Dan can tell you all about them if he ever gets on here
That is a really big compressor, you really don’t have that much air, I say go down to 175 and get a 495C That compressor is amazing. But nothing like an oasis, (sorry if i stepped on your feet Dan) you have the floor bro.
ok im new to trainhorns game thats why i ask the pros what u think my buddy wants to sell me the oais compressor or i was going to run another one for duel compressor?
yes sorry sir oaisis that is what i ment
It depends on the model your buddy wants to sell to you? Do you know what model it is?
(look a thread I can’t make suggestions in…)
Make sure you post photos of your installation when you’re done!
Lance, your input is always welcome even if you bring up Viair. These guys aren’t easily persuaded.
i just want somthing that will last i just have to get a bigger electric solenoid switch for 200 psi and 1/2
The 200 amp solenoid is already built into an Oasis compressor. You don’t need another one.
well i ment the pressure valve sorry cuz im going to run 200 psi now and the valve i got now is for 120 or somthing now when tank is full it wont blow cuz its to much psi so i need to get the heavy duty one 250 or better and i heard that u run 1/2 hose to the fitting that the trumpets are on then from fitting to trumpets u use 3/8 and it is louder??? what u thnk
Running that size air line to your horns will make sure they’re getting enough volume.
Did you mean pressure switch that shuts the compressor off at 200? If that’s the case then you want your horns LOUD, right?
I think he meant he needed a solenoid valve good for 200psi with 1/2" fittings.
yes u got it djQUAN that is all i need then how do i put pics up on install do i use photo bucket or somthing???
