Thoughts: Shocker XL with Nitrogen/Co2
First post here! Ive done quite a bit of researching here and I think Im going to go with:
http://www.hornblasters.com/products/details.php?i=shocker-4-train-horn
Powered by:
http://cgi.ebay.com/40-CF-WELDING-CYLINDER-tank-bottle-nitrogen-argon-mixes-/140452925097?pt=LH_DefaultDomain_0&hash=item20b3a58ea9
Along with:
http://www.toolfetch.com/Category/Welding/Gas_Cutting_Welding/Regulators_Flowmeters/331-190IN-175.htm
I have a 04 Impala SS, and Im pretty big into car audio. I also somewhat of a sound quality guy, so having a running compressor is out of the question.
From what I can tell on these forums running a nitrogen/co2 tank isnt very popular. I dont plan on driving around blasting all the time. I want it quite simply to scare people.
So, based on the stuff I posted above, how would a system like that compare for example to the $500 horn/compressor kit? My main concern is if the regulator will be able to provide enough flow @ 150 psi to the shockers?
Thoughts on this setup?
I use a similar regulator with a set of Shocker XL’s and it works fine.
Well, It turns out I couldnt find a good local place to get tanks filled, so I went with a tank/compressor.
You couldn’t find an industrial gas company to do it for you? What’s your closest big city, or your metro area?
Kris
You can usually find Co2 at a welding supply.
Im in Jacksonville FL.
Im happy I didnt go with the c02 option now. My biggest fear was excessive compressor noise/vibration, but after a little fabrication, and the Viair mount, I can barely tell the compressor is on!
Glad it worked for you!
Kris
