toyota alternator cannot run compressors
i have discovered that with a combined load current of 77 amps at 13.8 volts, my stock Toyota Tacoma 65 amp alternator does not have enough output to run all three air compressors simultaneously. I will need to look into and alternator with a higher output current and possibly a second battery plus a battery isolator.
When the 3 compressors are running, it starts out running fast and smooth, but as my battery slowly drains and my voltage drops to a dangerous 10.5 volts, the compressors begin to run slower and slower, and are on the verge of stalling. If the compressors stall, that means they will burn up. I am not sure if they have a low voltage protection or not.
Wrangler northwest power products makes alternators for ambulances and limo’s and seem to be very good. They said they can hand make me one with a predicted max output of 175 amps and an idle current of 100 amps for $800 .
I just thought all you “techy’s” would find this interesting.
install pics will be posted soon.
800 seems kinda steep… atleast to me.
I went through DC power for a 2nd alternator setup. They are a good company and have reasonable prices. I don’t think I spent that much for the whole kit. 230amp + brackets, etc…
I’ll throw the BS flag on that one. Someone is trying to rape your wallet bro.
The cost of a new high output alternator shouldn’t be more than $200. Swing by PepBoys, AutoZone, etc., and ask how much one costs. With the right tools you should be able to install one in under an hour.
A second battery next to the compressors is a good idea. My diesel rig already has two with a 165 amp alternator and I’m considering a third battery (possibly deep cycle) with 2/0 welding cable to connect it to the other two so I don’t put as much strain on the stock batteries, or I might just switch them out to industrial sized batteries.
Kris
I just got a 280 amp dc power alt. to replace my 145 amp in my silverado… I’ve yet to install but hear great things about them . And It right around $400.
For the heck of it I checked DC Power.
They show 3 choices for a 2000 Tacoma with 4.0L.
https://www.dcpowerinc.com/alternators.html?id=157&category=%3F&year=19&make=155&model=523&engine=1102
Serious overkill … nice!
Kris
130 amp for less than $200: http://www.maniacelectricmotors.com/hiou120amp1914.html
120 or 150 amps alts here for $240 max.: http://www.mralternator.com/alternators/toyota.html
LC Engineering 110 amp: http://www.toyotacatalog.net/M1WebGear/ProductDetails.aspx?PartUniqueID=D1977003-A63C-482C-9697-F57A99D79B58
LC Engineering 140 amp: http://www.toyotacatalog.net/M1WebGear/ProductDetails.aspx?PartUniqueID=2576465A-07B5-4738-A34C-1ED631320D84
LC Engineering stuff is bulletproof… Used to have a stage 5 head and cam in an old Toyota of mine. Damn thing was stupid fast…
FYI - you’re not likely to find a high output, custom wound alternator at PepBoys for a Tacoma. This will be a speciality-built unit with a higher price tag.
DC power, Mechman, or Ohio Generators are the only 3 i would deal wit and ive ran two of them. all very good alts and have great output at idle
I cant wait to install mine but i want to change my idler pulleys for ac and acc belts , plus the belts since i have this damn squeel/ whistle noise. Just have to wait out the weather!
