Train horn compressoming not coming on, solenoid getting hoton,silioned
Motor under compressor stays magnetic
Hi Frank, thanks for reaching out! If your compressor is not coming on, it could mean a wiring issue, or a bad pressure switch. The best way to test this would be to connect your compressor directly to the battery and bypass the pressure switch. If the compressor powers on, it would mean your pressure switch has gone bad.
Here’s an article from our help center that might help as well: Help Article - Air Compressor Not Turning On/Off – HornBlasters
If you still have issues feel free to give us a call at 877-209-8179 Mon-Fri 9am-6pm and we’re happy to help!
Where is pressure switch located?
The pressure switch is a small round or rectangular shaped device that will be screwed into a port on your air tank. It will have 2 or more wires coming out of it, and it will be wired directly to your compressor.
