Can you run a Nathan K3 and a Hornblasters Conductors Special off the same tank? I know the Nathans and the Hornblasters run off of different PSI’s, Can I run them off the same 7.5G Tank. Thanks for the input.
Cant see why not.
I run my tank at 120PSI with the HB xls. They sound great at that PSI.
both horns should be fine at the same pressure.
If you’re worried about pressure, do a search on the forums for the McMaster-Carr pressure regulator. It’s been discussed quite a bit, and would solve the problem.
Both can be run anywhere from 100-200 depending on your preference so don’t worry about it. But like MarineOne said a regulator is always an option if you want to run 2 different pressures.
Ok, Thanks for the help! Im fine running them both at 175, I just didnt want to mess up the shockers!
