Train horns Illegal in NYC??
Are train horn illegal in NYC? I just bought a onboard air kit #240 from hornblasters and I am wondering if a big rig horn @ 150psi would be illegal. Also how do I wire up a toggle so when its down the stock horn sounds and when its up the air one does?? thanks
It would be a noise violation if anything. as for the other question. Find the stock horn up in the front of the engine bay, you will have 2 horns. you can splice into one of those and run it to a toggle switch and then to the compressor.
Its all about being smart when using it. Stay away from the big rig horn tho. Go with some shockers! Much more effective!
It is highly illegal. I don’t believe they are legal anywhere. Just have some common sense when using them.
NYC has a lot of tunnels and underpasses, utilize them with your horns hahahaha!! good luck with the install
It should echo well when downtown with all those tall buildings.
U can test n find out…
probably not illegal to own, but maybe to honk haha
i would say it depends on how noticeable ur vehicle is… if there are a bunch of cars around theyll never know it was u hahahaha
Thanks ya’ll so much for the responses. I’m probably gonna get big rig horns anyways for when I tow 10K upstate NY.
Anyone know how big of a tire the 240 kit will fill up? 2 gallon 400C compressor, 150 psi pressure switch.
Not a very big one it might take a few fills lol
The Oasis XD3000 can fill any tire to 150+ without a tank.
Site says its rated for 33inch tire, could I go any bigger?
Sure just wait till it refills as many times as it takes and you should be able to fill 50’s
Thats what I figured, It would just take a while thanks.
no waiting on an XD3000
Ya, but I want my air for air leveling kit, horns, and to use air tools.
Its a high sitting f250.
stop teasing me lol
Ok, so you definitely need a tank but just one XD3000 can do all of that and do it 5 times faster & last 5 time longer.
