so recentley upgraded to 1/2" lines and solenoid, also just bumped my pressure switch up to 200 psi. so now when i blow my horns only 1 blows, then after about 2 secons my 2 kicks in and about another 2 seconds and my third finally kicks in. so it seems that they are sticking any thing i should try to keep this from happening
Which horns are they? Which solenoid?
Need some more details to help you.
Kris
Hello to you too! Welcome to the forum. Same ?'s as above, plus are your horns on a manifold or run separately? If separate, are all the line equal length from the valve/tree?
ya they are all on the same manifold, dont kniow what brand they are cause i bought the from a friend recently. ill get a pic of them tomorrow and post it up
what valve ru using?
