This is a Universal Air Suspension Strut airbags looking for $325 Shipped, (This kit retails $419). I was going to install them on a 95 Cadillac Deville, but I never got around to the project. These have never been mounted.
There hollow inside allows them to be mounted over factory struts suchs as Macpherson strut suspension and coilover shocks. Many common uses are found in the front of Toyotas, Nissans, Mitsubishi, Hondas, Dodge, GM vehicles, many universal applications. Sale is complete with two strut bags,universal brackets, and bearing kit. Lower Brackets must be professionally welded to strut. This sale includes two D7 bearing for Macpherson struts. Simple coilover shocks don’t need an upper bearing.
Item Description
Single Convoluted Air Spring.
Designed for to slip over your Factory/Performance Struts. (Pressure tube must be less then 2.14 in Diameter)
4.0" Compressed
9.25" Extended
5.875" Diameter
Bags made from Synthetic rubber to be resistant against Oil and breakdown that will ruin Natural Rubber.
Available in 1/4 NPT Ports
MADE IN THE USA!
NOTE: The brackets required to install these bags are 2 Flat Plates (Upper and Lower), Bearing Kit (You also can use your factor bearing plate for this application). Using the bearing supplied in the kit will allow you to achive an additional 1" Drop.
