This is kinda carrying on with a post about a problem I had in another thread.
I have two compressors, both 400c’s.
The first one is approx 6mths old & blows 30amp fuses after a couple of minutes, especially if you stop & start it & runs slightly slower than normal? I might add, the leader hose is not connected.
The 2nd one, was used less than 5 or 6 times & does not seem to pump?
I have sucked down down the leader hose & the ball valve is working correctly, only letting the air through one way.
I have blown into the hole where the air filter goes & air comes out of the leader hose & if i sucked the same hole, no air comes out, proving the check valve is doing its job.
When I connect the compressor to 12v’s it purs away & runs nicely, but no air comes out the leader hose???
I’m wondering if the check valve is faulty & I am able to suck the air through, but the compressor is unable to open the ball bearing in the check valve?
Has anyone else had a similar problem? I’m completely stumped!
