Hi there forum, i have my shocker kit, the 228vx and everything its ok but i whant to buy a better compressor for my hornblaster kit, one that fill my tank very quick, what compressor you guys recomend me?
As far as I know, the Viair 400c is the fastest filling compressor that Viair makes. It is 33% duty cycle so if you want to be able to run the compressor for a long long time without worrying about it, you might want to go with a 100% duty cycle compressor, but they aren’t quite as fast.
Your kit came with the Viair 280c
Take a look around for the one you want…
http://www.viaircorp.com/OnRoad/cmodel_compressors.html
Well, I’m waiting for my post to be approved!! But in short, a good option would be to upgrade to the Viair 400C compressor.
Your kit comes with the 280C compressor. It fills a 2.5gallon tank from 0 to 145PSI in 281 seconds.
The 400C compressor does the same in 140 seconds, so half the time!
Those numbers are on the Viair website under ‘onroad products’
Ooh waw thanks for that info man, it help a lot
