So this is what happens to the two temp gauges as i mess with the A/C blower. Not supposed to happen. Iv been trying to fix this for a while:mad:
I’m having a blonde moment? Whats happening with your gauges?
As i increase the blower or fan speed on the air conditioning, you can hear it in the vid, the temperature increases because of a wiring falt. those temp gauges read the air zenith temperature.
Ahhhh I see now, told you I was having a blonde moment, I never realised it was a vid, sorry.
A ground problem or voltage drop? Does it still do it whilst driving along or only on idle?
I think its a ground falt. I have had a problem in the past were one of them was reading to high so i bought a new sensor. Problem is it wasn’t the sensor but ended up being a grounding problem. The gauge reads the resistance across the line and translates it into temperature.
And it does kind of have its spaz out moments when im driving… it will start and stop…
