i am kinda new at this and i am looking for a good way to get a nice train horn sound and an easy install, that isnt terribly expensive. Any advice would be helpfull
ok the shockers are really nice kits, very easy to install and not that expensive… if you want a real train horn get a nathan airchime they are veryyyy loud and easy to install too
thanks for your help its a hard decision as someone new to this it all seems like another language
this is an expensive hobby but you get what you pay for. like with most things
plus its kinda a one time investment once you get where you want to be
Short:
I’d definitely recommend the Shocker 232 XL kit: http://www.hornblasters.com/products/details.php?i=shocker-232-train-horn-kit. It’s a great match of authenticity, ease of installation, and price. The horns are American made, tuned, and come with a lifetime warranty; the air setup is also great quality with a brand name, high output compressor, and a premium air tank.
Unlike a lot of other horn kits, the Shocker horns can be mounted independent of one another: you can place each horn anywhere and in any direction since there is no manifold. This makes installation much much easier!
For what you’re getting its the best bang for your buck.
Long:
Are you installing it on a vehicle? If so, what kind? Room can be an issue with some of the larger horns.
As far as authenticity goes, AirChime P3s, P5s, K3s, K5s etc are real train horns: the very same used on actual locomotives. They’re American made too! They all require a pretty hefty air setup though (we recommend 5 gallons and up).
If you’re looking for something that costs a little less money, the Shocker horns are a great alternative. They are American made and hand tuned to play a locomotive chord. With these you can get away with a much small air setup as well.
Lastly there are import train horns. They usually come in a three-bell stack about the size of a P3; usually in chrome finish; and usually don’t sound all that great. They’re definitely a loud horn, but not too much more.
http://www.hornblasters.com/products/category.php?c=train-horn-kits-and-air-horn-kits
We offer a pretty wide selection of horns matched with compatible air systems. I’d recommend any of the Shocker XL or AirChime kits.
As far as the air systems go: larger tank sizes mean you can honk for longer without waiting for the compressor to refill; larger compressors mean the tank fills up faster; and higher PSI means your system will be louder.
Hope this helps a little.
