Whats up from sunny sd
Whats up everyone. Im new the the forums here and just want to say whats up. Im ordering some shockers this friday and want to know how easy installing the horns is? I drive an '06 Tacoma so if anyone has any good ideas about how to install em in an area that will keep em top notch. Hit me up
Welcome! the shockers are really easy to install so don’t worry about it
thanks. Is it ok if I install the tank and compressor setup sideways? or is that a bad idea
the tank i think will be ok but the compressor i don’t know lets ask lance…
WELCOME! the compressor should be ok sideways too as long as its not upside down
Viair makes brackets so the compressor can mount upright on a frame rail
thats another option
Awesome guy thanks a lot. The compressor is mounted to the tank. Can it be removed? Or should I keep it on the tank and just mount everything sideways?
Welcome, you should be able to remove it without damage unless they’re welded together. Consider the space where you plan to mount it before deciding if you want to remove the compressor from the tank.
Welcome to our forums!
If you want to mount a unit underneath the bed of the vehicle, check out the Shocker XL kits.
Reason being, the tank and compressor come separate from one another. This allows the customer more options as far as the installation is concerned.
The VX kits are for the customer that wishes to mount a complete air source unit upright inside either the bed, cab, trunk, or tool box of a vehicle.
Please PM me if you have any questions.
Good luck!
the one u have is the all in one tank and compreesor i dont think u can take that off
Mate…welcome to HB… You’ll love ya Shockers!!! I woz tight for space fitting mine on my car, so I thought sod it & stuck the whole lot in the boot!!! So pleased I did now!
Good luck with your install dude!
