Wiring diagram for momentary button
First: Thank You to the poster who did the original attached img.
Second: Is this correct ??? All I have done is removed the toggle switch so the compressor only runs when the ignition is on.
Again, kudos to the original poster for the diagram…I work better with pictures…:smiley:
BTW, I’m using a nitrous/trans brake button that has a coiled cord that will tuck nicely into my center console under the front seat…no switches or buttons visible—stealth.
Somebody posted that schematic & I doctored it.
It still says “toggle switch to power compressor”, but I see where you deleted the switch - and the common ground stuff. Anyway, yes it will work. You just won’t have a master shutoff switch. You probably don’t need the 6 circuit block either.
Thanks ear2ear ! Its just reassuring to have a second and more experienced set of eyes look at it before I start running the wires. I thought (there I go thinking again) that the 6 circut block would be nice for any future needs. Everything is already installed and tomorrow I will finish the wiring.
Thanks again !!!
OK, I corrected the diagram nd attached it…maybe a sticky ??? Thanks
